Hello, I am looking into restoring some paint work what is the correct way to do this as I will be using spray cans as small jobs. can you really get epoxy primer in a spray can if so which one is best and true? please
Bare metal, prime with epoxy if it can come in a spray can, Filler, epoxy primer, top coat and clear coat.
Bare Metal, etch primer cant be filled over? high build primer, top coat then clear coat.
Bare metal, fibreglass filler also as a sealer, primer filler high build, top coat and then clear coat.
Aslo sills, etch primer, stone chip paint or rubberised paint?
Bare metal is in hard to reach corners and will not be able to get to all the rust spots
Thankyou very much in advance this has been baffling me for weeks now and needed to ask the experienced pro`s
Yes, a rattle can is an efficient way of layering paint, but because of the small nozzle size and pressure, the contents has to be so thin, its often neither good as use nor ornament as there's no substance in them. They have their uses but car refinishing is pushing it slightly despite what "The tall man" says.
