My OH got mine in the nearest branch (Carmarthen, W Wales) for me as I was unable to get there.None in today at Sevenoaks Lidl and I was quite early too. Not even any sign that they'd had them in.
Last time the store had 4 units, & a queue waiting for opening - gone in seconds.
This time no queue, and OH estimated there were 12-15 units at least available.
i never looked much at the wire, is it any good? just plain wire on small spools?I went this morning for some 0.6mm Mig wire, local store only had 1 roll, but at least 3 plasma cutters.. resisted the urge to buy one..
Just got back, went to another local store and bought another reel of wire, they had several, tempted to buy 2 more…they also had at least 3 plasma cutters, but again resisted..I can’t really justify £150 for summat that I’d use once in a Sheffield flood….besides, ain’t got any matl that would require a plasma for cutting…
Im sure some of these cutters will appear on marketplace at vastly inflated prices…
Dunno, all I know it’s gasless Mig wire, they had 3 sizes, 0.6/0.8/0.9. For £5 it’s worth a punt imho..,i never looked much at the wire, is it any good? just plain wire on small spools?
could be handy for my little kemppi mig
I knowplenty in stock in Orkney, resisted the urge to get one though.... i alread have 2 plasma cutters!
i did think about it for the farm though, but i might just finally look for a new torch for the old cebora prof 50 instead, its a good machine still!
I hooked mine up last night just to try it & check it worked.
Connected to my 100L compressor, connected up the Torch & Earth, dug out some old 3mm thick slightly rusty Angle & an offcut of 30mm box (still with millscale on)...
Pilot arc ok.
First efforts at cutting I was underwhelmed, then it got worse.
The replaceable end looked kaput really fast, & the nozzle underneath a bit too.
I changed both & had another go, and it was definitely better.
I dare say it takes a bit of practice to he able to use one half-decently (& maybe I was the problem that screwed the first tip?).
Somehow I expected it to have more oomph given that its supposed to cut 9mm steel![]()
Good shout! You're bang on - I just tried it with the fitted bits - it never occurred to me that they might not be fitted correctly (dumbass mistake in hindsight). They did seem only finger-tight when removing now I think on it.Did you fit the first ones yourself?
If factory fitted they might not have been tightened correctly.
Also, the quality of the cheap consumables seems to vary with each one so I wouldn't be surprised if simply swapping them over improves things.
They don't make a massive issue out of cutting 3mm thick. Get a bit of 8mm and see what happens before judging it too much..
I do have my 50yo 150L (I think, though it might be 200L) Ingersoll-Rand model 30 which I can hook up to it - I tried on the 100L Clarke as its a lot more portable - but yes, next time I'll try running it off the hefty lumpCheck you have sufficient air coming out of the nozzle.
Just because you have a 100 litre tank on the compressor doesn't necessarily mean your compressor is coping.
I found out the hard way that the nozzles burn out fast with insufficient air.
First time when I forgot to turn the compressor air tap to on.
Second time when the Aldi compressor died ...
