redlig
- wiltshire uk
Nothing wrong with a TROLL . T6 version that is.
? Lost in translation ^tea odour
It's a 1kzte diesel.Forgot exactly, but its a 3Y or 5Y engine pattern isnt it ?.
The 1kzte 3.0 diesel lump
^Its really a shopping trolley. AND !!! I would NEVER own a GM produced car,
which is what OWE dee is.
Pm sent!Landcruiser 90 chassis and DIFFS and CONSTANT 4 wheel drive is KNOWN to burn the axle splines offa the axles. ( plus cook the centre diff )
NOT greatly different to MK I landy, which is the vehicle I learned to drive in. ( Or break a lay shaft ) 1950 model )
Anyway, as long as you like it, is all that matters. I dont want one, FOR FREE.
Au is a LIL tiny bit larger than UK, and, as I mentioned, Surf was never brought in by tea odour. ITS NOT an Australian version.
NO parts!!. ( not officially anyway ). No parts manuals. Toyota WONT help you with a surf, its NOT an australian import.
Its a bodgy!!. Wiring is totally a hodge podge of cobbled together stuff. ( I have been asked as an engineer to sort it out ).
90 series is also NOT a favorite over here. (9" rear diff, 7" front diff. ) Well, the full manual version will fetch a few bucks, but the fulltime four wheel drive, is hopeless.
BUT then for shopping in the high street 3.123554 kilometers from your estate, it will work for a while.
England would fit into Western Australia about 20 times
England would fit into Queensland about 14 times
England would fit into Northern Territory about 11 times
England would fit into South Australia about 7 times
England would fit into New South Wales about 6 times
England would fit into Victoria about 2 times
England is about twice the size of Tasmania
England is about 55 times the size of the Australian Capital Territory
I guess the point is, YOU never go anywhere!!. Its not uncommon for wifey, myself n Lily, the dog, to go 3000 kliks to visit our kids. Takes 3 days. Same state, QLD.
Sorry to be a pooh pooh, BUT you NEVER use the car as a country vehicle. Its really a shopping trolley. AND !!! I would NEVER own a GM produced car,
Daleyd has the answer !!!. half of india and pakistan have EXACTLY that vehicle.
They just uncouple the rotary hoe offa the front.
Joe
It seems to be be doing a lot of work, heavy loads too. I cannot fit a cement mixer in my vehicle. Them bricks would have detroyed the suspension of my 2Lt estate. I don't know the engine capacity, but I'd guess it it would tow a decent size caravan.Thats not a Tardis !!!!. Its a tea odour.
Can go thru water 20 feet deep, just have a look at the english tourists on the beach waving to the guy on the roof.
Very good in floods. Its always the car thats doing 50 MPH when everybody else is doing 10 MPH.
Its also a VERY good two wheel drive, one front wheel and one back wheel. The sunroof will let in more rain than is actually falling,
and it sounds like a grey Fergy with 25,000 hours on it without an oil change.
The salesman definately saw you coming !!.
Joe
It's a 3.0 turbo diesel, it will pull a pretty heavy load although some people put a separate transmission cooler on them if towing a lot of heavy gear up hills as they can get hot. I've not had any trouble though.It seems to be be doing a lot of work, heavy loads too. I cannot fit a cement mixer in my vehicle. Them bricks would have detroyed the suspension of my 2Lt estate. I don't know the engine capacity, but I'd guess it it would tow a decent size caravan.
I have one similar, a tiger, again a gas version. I suspect it will get "converted" to woodburner and ebay will be used, I have an oil boiler in my workshop, and a vertical gas tank conversion wood burner in the other...Back to the plot....Here's the latest item that I managed to save (luckily before it was actually put into the skip as it's fheavy and I doubt that I wood have got it out). It originally was made as a gas fire so is in extremely good order. Plan was to convert it back to a wood / rubbish burner for the workshop but now other plans have come along so resting in the 'what do I do with this heap'.View attachment 388320
Lee Peck, I think he has recently built a small batch of them. Lovely bits of kit.
Check out the "Kracken" - Mx5 based, taking a lot of inspiration from the T6. Seems to work from what I've seen of results.
