No welding today. I started digging, and removed the box over the wheelarch. Not good.
So - decided to bite the bullet, & strip out the interior, then lift the laminate flooring, then use the multi-tool to cut & lift a chunk of the ply base over the steel floor and see what's what.
Previous roof leaks have caused mayhem I reckon. Sections of the floor ply and base of wall ply are water-damaged & rotten.
The pics show plenty of rust to cut out including over the chassis rails.... so thinking to see if I can cut out and remove enough floor to give the access to repair & make good as much as I can from above - do my inexperienced novice best to do a half-decent repair job.
