My Old Landy
Engineering Mayhem
- North Lincs
I like the control cubicle. What HMI system are you using or is that confidential? I design control systems for a living so interestedYour sums are wrong. Energy given, gather than just stored needs flow. You’ve double counted height.
If you have 3.5m times 9.81 times flow (say 20 l/s down your IBC pipe?) gives you 687Watts, until your IBC starts draining lower and lower... I ignored efficiency, usually .75 or thereabouts.
The actual full calculation takes in specific gravity of the fluid of course, but since mostly water is used that neatly cancels out.
I say mostly, because someone who I’ve known for a few years has created a company to use a denser /heavier than water fluid, so you don’t need pipes as big, or as much flow etc.
And to the person who said small turbines are less efficient - no they aren’t really, most turbine efficiency is down to type, and how well they are designed and built. The pipe losses can wipe out a lot of energy, if the velocities are allowed to go above 1.7 m/s or so
Ai you did.
Say you stacked up 3 IBCs, (Or rather approximate 3 IBCs as a column of water 1x1.2m square, 3m high), that has a gravitational potential energy of 3600kg * 9.81 [m/s^-2] * 1.5m (Average height) = 53,000 Joules
You have a gravitational energy of 3600kg - this is due to height times the weight of water. Then you multiplied it by 1.5m ...
No flow equals no power.
And to counter @PhillipM , you would need to be down at micro sized bearings before the losses would increase enough to lose you efficiency, and even then it would be tiny and difficult to measure.
I’m not making this up, I do it every day, and have done for some years noView attachment 386745
A couple I built earlier...
I did find it quite good, but more used to working with Allen Bradley & Modicon stuff.
