hotponyshoes
- Somerset. Uk
Watching a Guy Martin thing last night and he was at a hydroelectric plant in Wales.
Some numbers given were
390 cubic meters of water per second flowing through generating enough power for 2.5 million homes.
Big numbers but by my maths that means each home is basically being powered by less than 10 litres per minute.
I get the economics of scale but, ignoring that, you should be able to run a tumble dryer cycle from an ibc full of water easily enough?
Then have a solar powered pump to send the water back up again..
Or, if you used a large amount of water (farms etc) fill the top tanks from mains pressure and use it from the bottom tanks)
Why is there not any small-scale hydro power around?
I suppose the height/head of water in a hydro reservoir will be pretty decent but (if you had the space) you could use multiple ibc's....
