ajlelectronics
- Gloucester, England
Wasn't it Yootha Joyce who was always looking for an Action Man with gripping hands? That just shows that it was a fictional comedy.Don't forget the gripping hands!![]()
Gizza job….Wasn't it Yootha Joyce who was always looking for an Action Man with gripping hands? That just shows that it was a fictional comedy.![]()
Looks very close to JD green.I like it.
Nice, question is, did you size the tiles to the window, or the window to the tiles?!Work in progress:
Finally got the rest of the marble tiles mortared onto the backer boards of the shower enclosure in the future upstairs bathroom of our 'old house' project. I used a polymer-modified mortar, which is extremely tenacious stuff; I had to replace one tile that somehow had slipped a bit, and it wasn't easy!
It was the first time I used this particular leveling clip system on a tile job, and I think it worked pretty well.
The next steps to finishing the tiles will be:
- Clean up the mortar remnants.
- Grout the tiles with a polymer-modified sanded grout.
- Caulk the outer edges.
- Seal the tiles and the grout with a high-end sealer.
I hope to get those steps done over the coming week or so, sandwiching them between other tasks I'm working on. My lower back has been acting up a bit, so we'll see how it goes.
Work in progress:
Thanks. It was a little of both. Here are a few details:Nice, question is, did you size the tiles to the window, or the window to the tiles?!
A leveling system can be very handy, especially when the backer board isn't absolutely flat. These backer boards were 'reasonably' flat, but not perfect, as they were installed on rough-sawn studs. The only thing I don't like about leveling clips is that if you get a little too much mortar behind a tile and it squishes out against or inside the clips, it's hard to get it all out while the mortar is wet, so it will require some joint cleaning after the mortar has set, but in this case it wasn't too bad. It only took about half an hour to clean the excess mortar out of the joints in preparation for grouting.Cheers, kicking myself even more, again, that I didn't use a tile levelling system![]()
Thank you. It was a little more work to do it that way, mainly because I had to be fairly precise. I had to re-cut a few of those tiles and do a bit of shimming under the tiles to get the corner bevels and joints to line up well. I bonded the mitre joints together with silicone as I was assembling the tiles, so they're well sealed.^^ I like the attention to detail with the mitred joints at the window, most would have just used butt joints.![]()
That's the kicker for me. My plasterboards and backer boards were dead flat, as was the floor. It was the perfect surface to tile on.A leveling system can be very handy, especially when the backer board isn't absolutely flat. These backer boards were 'reasonably' flat, but not perfect, as they were installed on rough-sawn studs.
Well, leveling system or not, it looks like you did a really great job! That represents a lot of work!That's the kicker for me. My plasterboards and backer boards were dead flat, as was the floor. It was the perfect surface to tile on.
Trouble is I'd never tiled before and got caught up in the moment. Started with the hardest corner first as well!
The blue lights (LEDs?) in the niches are a nice touch!
It could have been.....Yet another,6th since new year,3 more on order.View attachment 386208
Neat. How to you anchor it, resin? Also how do you finish/paint them?Yet another,6th since new year,3 more on order.View attachment 386208
