KemppiFrog
- Aquitaine
Hi
Just wondered if anybody had one or had worked on one.
Friend has asked me to try and sort out overheating. Works for about 15 min then the light goes on. It is hot, not just the light/sensor.
So, not loseing coolant, the thermostat opens (checked it in hotish water and tried without it)
The radiator is newish (two years) and coolant system always filled with antifreeze, no sign of oil sheen on coolant and it appears to flow in the top of the rad with some turbulant movement. Cooling fan OK and belt tight.
Looked on the dipstick and oil is clean, so don't think it is the gasket.
Engine is a three pot 23hp diesel. Not sure who makes the base engine, but it might be them. Spares are only available through the agent at steep prices, nothing on the web.
Next week, I am going to pull the water pump and see if that has problems, then, if that is OK, maybe pull the head.
Any other ideas?
Left it with the engine running and the cutting deck going for 20 mins, seemed OK. Then ran it for 5 min cutting grass and the light came on with the extra load.
It has a few years working on an estate, mostly cutting grass (lots of it) used quite hard, but it is generally well built for pros.
Thanks
KF
Any other ideas?
Thanks
KF
