Bryan Williams
- Manchester England
Evening,
Just moved house and noticed tonight that the boiler is leaking.
It's a Worcester Bosch Greenstar 241 junior combi mk 3.
Moved in a couple of days ago and turned it on that day, I noticed that the pressure was on zero so I opened the top up tap and it shot up to 3 so I shut the tap.
It seemed to work OK, the pressure crept up a little then stayed about 3 1/2,I know that's a bit high.
Bled all the rads.
It seemed to work ok.
Turned off the boiler bedtime.
Next day the pressure was on zero again.
I turned the boiler on to 3 and within 5mins it was up to 3bar pressure, I assumed that this was just the way it worked.
I did notice that the house water pressure was low so I turned the stop cock on fully today and go a bit more flow through the taps.
Just noticed this evening a drip from the bottom left of the boiler on turning it on.
Quite a bit at first but then slowed down to a couple of drips a minute.
The pressure has only gone up to just over 1 this time.
Turned it off now.
There's a guy on YouTube who strips this very boiler down and shows the various bits that fail,there's a lot, he's not a big fan of WB, thinks they're overrated.
It looks like one of the faults he has pointed out, a cracked/pinholed pipe to the bottom left and back.
Anyway, I'll get it done, but can I use it if I top the pressure up first or will it just complicate things.
Also, nearly forgot, there is no programmer/timer with it as far as I can tell, none on wall or boiler, just a weird box right next to the boiler. See pics.
The new place is a 3 bed bungalow so the boiler was probably adequate when installed, but it seems the only control is the temp knob and eco button.
Cheers.
Bled all the rads.
Turned it off now.
Cheers.
