malcolm
& Clementine the Cat
- Bedford UK
Don't ignore the above post. The front brakes on Fiat Coupes would jam on due to inside decay of the brake flexi hose. The outside of them looks fine with no sign of cracking.You may be chasing your tail. In my long experience, that problem is caused by the flexi hoses. They degrade internally and bits of the hose inner become detached and act like one way valves. Unless the hoses are brand new, I would have a set of Goodridge in there double quick.
Hi Malcolm,I changed the rear brake cylinders in my MGA last week. There had been a problem with the master cylinder which caused the pressure to stick on and blow the seals in the rear cylinders. I replaced the rear cylinders. Tried to bleed the brakes but couldn't get pressure. The master cylinder was suspected bad anyway so I changed that.
I've been trying all day to bleed the brakes again. I've put a litre of fluid through and there is no more air coming out. Rear brakes are adjusted tight so they don't travel. I still don't get pressure. The pedal goes down to the floor and takes another 2 full travels to become firm.
Logically it must be the rear cylinders as that's when the problem started. They are funny things that require an internal spring. I wonder if the aftermarket suppliers all include the spring. Maybe I'll order some reassuringly expensive ones from one of the major suppliers.
What else can I be missing? I've never had trouble bleeding the brakes on this thing before.
A lot of BMC / Morris repro parts are made in India
I also have an MGA, 1600 mk1
