Yes, body is still on the rotisserie requiring quite a bit of work still.I take it you have the rest of the car to go with it?
One of the prettiest Triumphs made I think. I remember when I saw one for the first time Mwnt beach car park if I recall..Yeah, and call it Vintage!
Not so much now, That was about 18 years ago when I had just picked it up from the galanizers. It's now underneath this:
Pictures?Yes, body is still on the rotisserie requiring quite a bit of work still.
Wow they are spending £££ up your way!
Not a bad 'barn find'I think I may have posted these before somehere...
'barn find'...
Then was stored outside under a tarp...
Eventually re-homed ready for restoration...
Engine out ..
All things considered, that doesn't look in too bad condition. How's the tailgate? I've just had to give in to rust and repair mine. A lot of sheet metal, welding, grinding and e-coating later and I have a tailgate again!I think I may have posted these before somehere...
'barn find'...
Engine out ..
It's actually not too bad, perhaps I should start a restoration thread. The tailgate is not too bad, there are a couple of areas where the screen rubber seal flange needs some work and the frame has heavy surface rust where the skin folds over.All things considered, that doesn't look in too bad condition. How's the tailgate? I've just had to give in to rust and repair mine. A lot of sheet metal, welding, grinding and e-coating later and I have a tailgate again!
Mine is all good now and yes, I also had to replace that flange, about three quarters of it in the end. The worst of the corrosion however was on the inside structure. I had mine acid dipped, twice, and then e-coated after repairs so hopefully shouldn't have to worry about it for a good while.It's actually not too bad, perhaps I should start a restoration thread. The tailgate is not too bad, there are a couple of areas where the screen rubber seal flange needs some work and the frame has heavy surface rust where the skin folds over.
If yours is too bad it might be worth considering a second hand replacement... I've seen them come up fairly regularly on The Bay.
Yesterday I acquired a water meter to see how prices compare to the fixed rateable value over the next year or so and today I acquired a failing ballcock valve in the loft header tank so my new meter can now log the water dripping out of the overflow![]()
