Popcorn
- 'ull
out of respect for our forum sponsor, try to link to something they sell. I work for Machine Mart, we sell lots of welders,
Thank you, do I need to buy mild steel rods if I’m welding mild steel together?The paton I have is the 250A pro power supply...out the box it's a stick welder....but you can also buy a wire feed and turn it into a mig too....runs on13A no problem.
I haven't tried the mig yet but the stick is excellent...I used it today to do 4 short welds...started first tap each time. Not the cheapest machine...but not crazy money either.
I have this one...they also do a 160A version thats cheaper but I figured a 250A mig might come in handy.
Paton PRO 250 MMA Welder
Key Features 6MM maximum electrode capacity IP33 protection class for increased reliability in dusty and humid environments Pulse MMA Capable of pulse DC TIG and MIG with optional accessories Made in Europe 5 year warrantywww.weldingsuppliesdirect.co.uk
For rusty crap you're better off with 6013s. 7018 for a stronger joint. Or at least that is what I've seen.7018 rods (low hydrogen for rusty crap)
7018s are better for a stronger weld granted, but they seem to start and restart better on rusty quarry crap, which I used to do plenty.For rusty crap you're better off with 6013s. 7018 for a stronger joint. Or at least that is what I've seen.
This where we find out they're structural steel cages used to support bridgesWhat are they anyway? Sculptures I’m guessing?
This where we find out they're structural steel cages used to support bridges![]()
I never had as much joy with 6013s
OP - you’ll be fine with either for your armatures.
I’m a willow sculptor; this one isn’t finished but you get the idea. I want to go bigger so I need to learn to weld armatures7018s are better for a stronger weld granted, but they seem to start and restart better on rusty quarry crap, which I used to do plenty.
Will that grow?I’m a willow sculptor; this one isn’t finished but you get the idea. I want to go bigger so I need to learn to weld armatures
Thank you, it’s good to see the welds up close and I understand what you meanI used a clarke 130 amp Mig welder on this for years, more than enough power and leaves a nice clean tidy weld that does not need dressing or grinding.
Runs happily on a 13amp plug as did my 180 amp Butters Mig
These are made of cold bent 8mm mild steel bar I prefer top use the black finish stuff as its easier to form than bright cold rolled and a lot cheaper.
With practice you can radius the welds off as in the close up photo, just make a couple of passes close in and twist your wrist almost as though you are using a pallet knife with clay. Hard to describe.; easy to do
View attachment 384053 View attachment 384054
No it’s not living willow, it’s dried Black Maul but some people do make them so they’ll growWill that grow?
