theres a specific weed killer for mares tail , its ticket only ,,, and needs doing right at the start of growing season ,,, ive some mares tail that needs done and the times getting close.none of them get rid of mares tailglyphosphate salt or sbk
got mine from bruv inlaw who worked for british railApparently, Glyphostate is what the Railway Co's use to control weeds but it's a much stronger formula, which is not available to the public.
I was too, the black stuff on/in the slabs was horrible, it took several gallons of varying patio cleaners, moss killers, algae killers. Eventually I screwed two wire brushes to the head of an old broom and physically scrubbed it all over. That worked.Even the dog's scared.![]()
That's what I did last Spring, came up pretty good.Brush/spray a weak bleach solution on there, leave awhile, rinse off.
Ammonium sulphamate kills off everything, if used correctly. Waxy leaved plant, including mares/horse tail, you need to add a few drops if detergent to wet the leaves sufficiently.none of them get rid of mares tailglyphosphate salt or sbk
Dunno about dead but it’ll certainly be limp.Get 100 of these printed and scatter them about the area...be dead in 7 days
Salt.
Table salt. Available on eBay. Kills everything, except chips.
I was going to buy some late last year. The cost put me off, its gone up so muchAmmonium sulphamate kills off everything, if used correctly. Waxy leaved plant, including mares/horse tail, you need to add a few drops if detergent to wet the leaves sufficiently.
Or snap the top of the stalk off, shove a solution of it down the stem with a plastic syringe.Ammonium sulphamate kills off everything, if used correctly. Waxy leaved plant, including mares/horse tail, you need to add a few drops if detergent to wet the leaves sufficiently.
Neighbours did give me funny looks as I crawled about the garden, under bushes, behind trees, in goggles and gloves, injecting plants . . . but a decade later, still got none in the flower borders.
In the lawn where it blends in however . . . but regularly mowing keeps it invisible so I'm not bothered.
i was working for a crop sprayer who used to buy it. it had a hell of a dilution rateApparently, Glyphostate is what the Railway Co's use to control weeds but it's a much stronger formula, which is not available to the public.
This stuff? Good?Gallup XL... Good stuff.
Sprayed the edge of the neighbours overgrown garden with it... within a few weeks just about everything around a metre in was brown and dead.
