You can only go so far, if the screw is worn it will be in the middle of its travel. But compensating for nut wear is doable.Ambigous grammar. Previous post. It's the nut that was re-bulked using solder not the screw.
You can't wire up a two speed motor to the same vfd as you have to set how many poles the motor has in the parameters of the vfd
If you say so.Generally, the only reason you set the number of poles in the VFD is so it displays the motor RPM correctly.
Setting the number of poles changes absolutely nothing that comes down the wires from the VFD.
RPM display is very much an optional feature, not fundamental to how the VFD operates when driving a motor of either type.
The lockout is recommended just so you do not try to change speeds when the VFD's output is high. Two VFDs are not required.
It is easy enough to convince yourself if you are sceptical. Set the VFD for 2 pole and put a sillyscope on the output. Take a picture of it. Change the VFD to 4 pole and repeat the process. Compare pictures.If you say so.
Well i'm guessing the OP isn't going to be using an absolutely bog standard basic VFD let's call it a 'Dumb' VFD, but will be using a chinese unit which have programmable features.It is easy enough to convince yourself if you are sceptical. Set the VFD for 2 pole and put a sillyscope on the output. Take a picture of it. Change the VFD to 4 pole and repeat the process. Compare pictures.
As far as I know, the current setting is really just an "alarm", the drive will shut off if it detects the current going over the threshold to protect the motor, not setting it is no more dangerous than plugging a motor directly into the mains.You cannot input two amperage settings for the two different sets of windings, how do you tell the VFD that, without it thinking you're over-current, or it not applying over current protection to the motor when using the lower amperage set of windings.
Ah yes I also had the two-speed motor one, It is wired in 16A 240v supply to a Single phase 240 to Three Phase 440v Chinese VFD. The two-way switching is done using the original Colchester switching gear which is wired in-between the VFD and the lathe motor to set either low or high speed.@Lewis_RX8 hi there iv recently purchased a Colchester triumph 2 speed motor 400 to 440v would a vfd 220inpit to 380v output 7.5kw run it with changing configuration on motor also did you wire your 2 way switch between the motor and vfd or to external controls on vfd thanks
Are you ready for a go with the ainjest ?
It's a real game changer , I run out of bottle at 1000 rpm .
Just make sure the stop is set securely , safety squint set to max and let her rip !
...can’t seem to find a manual anywhere
I see looks like @argosheild may have on there I did not fit a braking resistor to mine so don't think I am much use but will have a hunt for what paperwork came with it and see if there's anything useful.@Lewis_RX8 looking to buy the same vfd as you can’t seem to find a manual anywhere I want to see if the vfd can be wired to a external braking resistor cheers
