Scalarocco
Smile, or I'll bite your leg...
- Rossendale
I get that and understand about standardised design to keep costs to the manufacturer down. Both of my cars have a notification when they are due an oil change. On each car there is a process to follow where you can reset these warnings from the drivers seat just using the ignition key and a combination of button presses. No additional laptop, autocom or anything else. Simple. If there was a sub-menu that allowed you to reset the brake caliper built into the car and the car did it, then that would be perfectly acceptable to me. It is possible to put it in a place where a muppet can't accidentally reset it while trying to tune the radio, so user safety isn't an excuse not to do it.Problem is, at the economies of scale in car manufacturing, and the need to make each car quicker and easier, and the design of car interiors, fitting a lever/pedal to a sufficiently strong structure somewhere in the car, routing a cable/cables, provide a means to adjust it, mechanism in the caliper to operate it (time consuming to assemble etc) and its cheaper to make it bolt on, plug in.
