slim_boy_fat
 - Scottish Highlands
T slots are 0.500” wide at the top, widening to about 0.875” at the bottom. Overall depth is about 0.875”
I'll measure up first chance and let you know.
I'll measure up first chance and let you know.![]()
When using a centre finder and no DRO, do you just touch off one edge and then calculate the centre from the part diameter?Yes, nice to have, eventually, but definitely not essential - how did all those machinists manage, before DROs became readily available? My first milling machine was never fitted with a DRO but it sufficed for about 15 years, before being superseded.
DROs do make operation so much easier - but the current generation will likely never know how to cope with hand wheels and backlash. A bit like ‘oiling the dipstick’ in your car engine, these days - many would not even know how to top up the oil, if the level was low.
Cheap Chinese DROs are fine everyone uses them. No need for fancy expensive ones!T slots are 0.500” wide at the top, widening to about 0.875” at the bottom. Overall depth is about 0.875”
Never!
I already have a MT2 boring head, which came with the lathe. It takes 3/8” tools, which aren’t in the arc catalogue.
DRO will be fitted in the future, as the decent ones are quite expensive. I’ll muddle along till then.
I haven’t got any particular plans for its use, beyond general repairs and making bits. As I said in the original thread, sort of a mill equivalent of my Boxford. At the moment, just looking for a starter set of tooling. One project might be a Hemingway fixed steady for the lathe.
@RichardM should I remove the moving jaw of the vice and skim the whole bed?
Mill is now installed, table stoned and trammed:
Yep, too big. Thanks anyway.@Guineafowl Had a measure today, I suspect that the clamps would be too big for your machine. Sizes here
You can confirm [or otherwise] if they'd be any good for your mill.![]()
Ok. Which one have you got?Cheap Chinese DROs are fine everyone uses them. No need for fancy expensive ones!
Just type DRO into Ebay - they are all basically the same.Yep, too big. Thanks anyway.
				T slots are 0.500” wide at the top...
You've got a mill, make some
I bought a 7/16 clamping kit from Amadeal: https://www.amadeal.co.uk/acatalog/Clamping-Kit-7-16-AMA_AC_400_3437TD.htmlT slots are 0.500” wide at the top, widening to about 0.875” at the bottom. Overall depth is about 0.875”
They may fit mine if no one else is interested. I’ll confirm in the morning as it’s snowing now and it’s gone Guinness o’clock if that’s alright John?@Guineafowl Had a measure today, I suspect that the clamps would be too big for your machine. Sizes here
You can confirm [or otherwise] if they'd be any good for your mill.View attachment 377711
You've got a mill, make some![]()
 Fair point.D71its original one
stuck a VFD on it
