The route of the pipe is right in front of the kitchen door. I guess I could put it through one of those rubber ramps that stops tripping over cables/pipe. The boiler sits in a corner, but doors to the hall and the lounge are on either side.Cant you replace permanently with neatly routed copper above ground? Permanent solution then and easy to get a 10mm roll of copper pipe and compression fittings to suit. Easy DIY.
Yes; I suspect that 10mm is too big for brake pipe use.Plumbers merchants should have some and the compression fittings
Screwfix sell 10mm copper pipe and compression fittings to suit.Yes; I suspect that 10mm is too big for brake pipe use.
