Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
You my have a long waitA couple of the £100 plus mini diesel 4 kw heaters to blast out hot air when you need it m you can use extra heat resisting pipes to pipe the heater air to so many areas .
Check out Skotls interesting and very informative install thread and check out some of the links for heat resisting pipe work
0.5 litres per heater per hour or so mid range heat , The don't take a lot of time or make mess to install them. Most local fuel delivery companies can / do supply heating oil in 45 gallon barrels if you ask them .
Just got a notification, the one I purchased off eBay supposed to be here 19 Dec , seller told me a few min ago it is out of stock, but three days ago I've already had a notification it has been dispatched and collected via Evri and is out for delivery
I think / hope it is because I contacted the seller asking what height the fuel pump could draw fuel up to & not reading English just hit the normal Chinese " No stock " reply button
Trading tadards have impounded a consignment at port. Said the installation manual was inadequate
