Dr.Al
- Gloucestershire, UK
Many thanks for that Dr AI, I appreciate the heads up. Is QCAD easy to find?
QCAD - QCAD: 2D CAD
QCAD is a free, open source 2D CAD system for Windows, Linux and Mac.
I am cautious of using a CAD system that may become chargeable as these companies have a habit of trying to squeeze whatever they feel they can get from you. As we do this for a hobby there are periods of time where I may not use this for months - I can't afford to pay £90 for something I may use for 2 weeks in a year. I also don't want to save something in a file format I can't open with something else.
My primary uses will be 3D printing (considering a Prusa) but also items fabricated using laser cut steel plate (anything up to 12mm).
That would be two different software packages for me... Fusion for 3D object modelling, and I have access to AutoCAD at work for 2D cutting files.
Just to reiterate what someone else has mentioned in this thread, don't underestimate the value of parametric modelling. In Fusion I can sketch a profile for extrusion, add fillets to it, cut another volume out of it, punch some holes, chuck some thread in the holes, etc, etc. If I want to I can still go back to the first sketch to edit it, and Fusion will automatically update all the follow on actions based upon the revised profile. Fab!
I also have a Prusa printer... it's been great. Nearest thing to plug and play, it pretty much worked straight out of the box.
mtt.tr said:It's also worth learning to draw with a spreadsheet to link holes and locations, change the inputs the whole lot updates.
I can understand the appeal of that efficiency, but the thought of 'drawing' in something like Excel frankly fills me with horror.
One of my assignments at college was to model a combination spanner, it was all driven by a table of dimensions so if you wanted a 10mm combi spanner you just told it you wanted a 10mm AF spanner and it would draw it. If you wanted 19mm AF, just input the 19mm and it would redraw the spanner to suitAny parametric cad worth it's salt will.
This is how I make various size tooth pullys in fusion and freecad
Both OnShape & Fusion have lots of online tutorials. FreeCAD does too, but some of them are for older versions of the software and can hinder rather than help.Fantastic feedback folks, I really appreciate your time. I will start listing the pros and cons. One thing I have not mentioned is the online tutorials which would be a great benefit to help me learn to use it, so good backup that way will be a great advantage.
Just to reiterate what someone else has mentioned in this thread, don't underestimate the value of parametric modelling... ... If I want to I can still go back to the first sketch to edit it, and Fusion will automatically update all the follow on actions based upon the revised profile.
I was just going to say the same.Both OnShape & Fusion have lots of online tutorials. FreeCAD does too, but some of them are for older versions of the software and can hinder rather than help.
What would also be good is more in the way of written descriptions (with lots of screenshots) of how to do stuff. I get very annoyed when I have to watch a 20 minute video when the content I'm actually interested in is only about 30 seconds in the middle of the tutorial and it then turns out that it doesn't apply to my situation anyway. If it was written with screenshots then I could scan down the page and find the bit that's relevant.I was just going to say the same.
I found myself going round in circles watching tutorials.
One thing that would make a good youtube channel is a fusion expert being asked to create "something" and whilst they create "it" , actually recording the screen.
Then audio dubbing/commentating with a voice Overlay explaining what's going on.
I often find a tutorial that seems to explain what I need to do. But then going into doing something 1. I don't need but 2.confuses me. Then I find out its because the tutorial is an old version.
