...a Stockton crack-hooker.
I keep meaning to make some T-nuts...
If you feed from the low side first, yes. If it does it both ways then something is loose.I can see that , but surely the cutter would be lower one side so only cut once ?
What he said.If you feed from the low side first, yes. If it does it both ways then something is loose.
Aand, as @Scalarocco alluded to - something loose - that could be the quill bearing, allowing a few thou of quill float. Easy to check, dti vertically up underneath it, and use a suitable knee and lever to try to apply some lift.What he said.
However, it's also worth noting that with a fly cutter with a reasonably amount of stick-out and a relatively slim diameter cutter, there may be a (very) little bit of flex in the bit. That could result in it taking what is effectively a spring pass on the second edge, even if your head is perfectly trammed. If that's the case then to get rid of it completely you'd have to deliberately tilt the head (by a fraction of a degree) to lift the trailing edge slightly.
