angellonewolf
- bristol england
Looking for an easy way to derust this tank not going to loads of trouble as it only a generator tank
I looks to me to be most surface rust
My thoughts nuts and bolts and a lot of shaking
2nd citric acid in water over night would I'd expect get it sparking vlean (I've done this befire and then had a hole in the tank)
Only problems I can see with any options is the fuel inlet has quite a ridge inside so it's not going to be easy to just turn it upside down
There is a fuel tap attached I'm assuming from another thread this is lightly to have a mesh in it so just draining it that way does not look easy
Are they easy to remove and will it just screw back in and be straight with out replacing the rubber washer (that I'm assuming that is there on it)
