Hood
I am obsessed.
- Carnoustie, Scotland
Was cutting some more 5mm 5083 up today and remembered to take a close up pic for youWhat is the cut surface finish on the alloy? Have you tried the raise the water level yet?
AluminiumLovely work @Cheesie! Are they stainless or alloy?
And for completeness here is the finish on 12mm 5083What is the cut surface finish on the alloy? Have you tried the raise the water level yet?
I hope you appreciate posting pictures like this is making me feel inadequate.
I've learnt to weld aluminium using this site and youtube I make bird cages for a living, I enjoy making this stuff in my garage theres super talented people out thereI hope you appreciate posting pictures like this is making me feel inadequate.![]()
How much energy does the water jet use? Some of them are scary I understand.And for completeness here is the finish on 12mm 5083
And as I have also just cut some 5mm steel I took a pic.
Consumables, if anything, are lasting a bit longer but it has been a while so... It is certainly no worse, I can say that with confidence. Regarding the torch, so far it has been fine and that must be a couple of years.All top dross, not much at all on the bottom
I really don’t know about water tabling mine…..
I’ve got a down draft at the moment but it has actually increased heat back to the work piece. Which is a real pain in the hoop when it comes to stainless, which I do a lot of.
Wondering if water is the way to go. What about consumables, water getting flung about, treatment etc etc? Trying to weigh it all up.
It is plasma.How much energy does the water jet use? Some of them are scary I understand.
Meant to say there is no bottom dross on the steel and the top just falls off if you wipe your finger over it as it just a fine spray like dross.All top dross, not much at all on the bottom
Maybe I just need to try it And seeConsumables, if anything, are lasting a bit longer but it has been a while so... It is certainly no worse, I can say that with confidence. Regarding the torch, so far it has been fine and that must be a couple of years.
I am using the Rocol V-Cut SS cutting fluid in mine diluted about 100:1 if I recall
Best thing I ever did.Maybe I just need to try it And see
Ahh sorry I misread - thought it looked rough for water.It is plasma.
