The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
A bit of brass.
After years of messing around with only half working jigsaws I got a decent one (Fein ASt 638)
That's a nice haul. What was the damage to your pocket though?
Fill in the internal angles with square plates so you can easily bolt on the castors and set th castors back a few mm from the edges so you can counter sink bolt them on.Got an Evolution mitre chop saw, very impressed with it, when locked in position it’s very steady with no movement.
Used it to cut some angle iron to make a base for some large metal cabinets, to sit in, onto that I’ll weld on wheels so the cabinets can be moved when necessary.
Just need to try to weld it together now to make something usable without making a mess of it
View attachment 368267 View attachment 368268
That's a very heavy indicator base probably to be used on a surface plateGot all kinds of things from that place. This is a bore gauge tester, I think
Taper turning attachment to offset your tailstock. Bowers. Will be top quality.It probably goes with that box of bits. This is probably my favourite bit I got. Bowers of Bradford. Appears virtually unused
looks like mine thatIt’s so lovely. This is what I actually went to collect, had one but sold it, regretted it hard afterwards.
View attachment 368459 View attachment 368460
That looks interesting... Any good?
