keithski122
It would be quite nice to have a bit of health and safety where I work.
I do apologise. I've never worked for BP so I'm not au fait with their inner workings.They have added in additional S now too
Health, safety, security and environment (HSSE) | Careers | Home
bp makes the safety and reliability of all of its operations the top prioritywww.bp.com
It’s proper dangerousInhaling the highly corrosive gas O2 as well![]()
Incorrectwhat annoys me is all these inspectors have there own take on safety and it isnt standard each have there own idea what to implement so every year inspections and reports are diffrent
We have a SSHE department so also added in the other S but another order just to be differentThey have added in additional S now too
Here is a simple fix for chuck key safety. This setup was on the drill presses and a similar one on the lathe start stop switches in my Jr. High School's metal shop. The student's couldn't start a machine without the chuck key being used. I think I posted this on the forum before ? Here's a quick sketch......................
Then the `H&S` prat got a wift of it and first thig he said was ` oh a lathe, can be dangerous, folk leave the chuck keys in` a bit risky.
We cant afford the risk.
which genius got rid of all the good kit and brought them in?Service providers
A company I worked for in the past made unwinding machinery for newspaper and magazine printing - the early ones had spindles that were inserted in the reel core and tightened by hand using a large t bar. (Later ones had automatic jaws)I always thought that the chuck key should be part of a push to make switch. If it's not in its rightful place then not pushing switch and no power etc.
Failsafe for people when leaving key in chucks etc.
.View attachment 367943
You can obviously not get rid of every risk but what you can do is sort things that are easy to fix, so why wouldn’t you?That’s sorted the Chuck key left in the Chuck issue, just need to make an isolator that needs tying back with the scarf. At the point you are convinced something has been made idiot proof a better idiot will prove you wrong. They are constantly evolving.
Bob
Accountants, or more properly bean counters.which genius got rid of all the good kit and brought them in?
Leaving the chuck key in is an easy thing to do, but equally it’s pretty easy to design something that goes a long way to making sure it doesn’t happen. Particularly in a learning environment where people are just starting out with unfamiliar equipment, have a lot of other things on their mind and don’t have the benefit of years of being perfect![]()
then implement it ,,, its a mind set not an enforcement option ,,,It would be quite nice to have a bit of health and safety where I work.
I mean thats just a strawman argument isn't it? Of course they should be familiar with it, no one is suggesting otherwise.Maybe, one could argue they should be familiar with and trained in the use of equipment before being let loose on it, probably the reason schools are off loading all their gear and phasing out metalwork/carpentry classes.
Bob
I seem to remember at college if you left the key in there was a device that would yell at you and poke you with a ruler...it was pretty effectiveSeeing how ape **** my instructor went when someone left a chuck key in has ensured I've never done it.
Couldn't start - unless a screwdriver, pencil, bit of round bar, or sometimes a chuck key, was shoved in the hole . . .Here is a simple fix for chuck key safety. This setup was on the drill presses and a similar one on the lathe start stop switches in my Jr. High School's metal shop. The student's couldn't start a machine without the chuck key being used. I think I posted this on the forum before ? Here's a quick sketch.
