If this is anything to go by:
BOXO 23Pc Terminal Release Tool Set
Description: Designed specifically for removing plug type connectors Quickly repair faults and corrosion Universal application Supplied in Power Case Bwww.boxo.co.uk
They are just re-badged tools, I bought this set for £29 maybe the foam is worth £200
Having looked a few of the bits on there scream neilsen
Where from?They are just re-badged tools, I bought this set for £29 maybe the foam is worth £200
Where from?
Thanks.![]()
23Pcs Car Electrical Terminal Wiring Crimp Connector Pin Remover Tool ReleaseSet 714367579054 | eBay
Find many great new & used options and get the best deals for 23Pcs Car Electrical Terminal Wiring Crimp Connector Pin Remover Tool ReleaseSet at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Good job I'm not after a terminal-release-tool-set then , even if I was I wouldn't entertain that priceIf this is anything to go by:
Bet the first one you need will be 22mm! And the 10 will disappear!Up date some of the sockets arrived today ( 3/8 semi deep ) and I'm quite happy with them .
View attachment 366839View attachment 366840View attachment 366841
the finish is pretty good , the recess for the nut/bolt doesn't go right to the bottom which I like . My only minor moan would be the knurling could be a little deeper / sharper not that you couldn't grip them with oily fingers . I will be buying some more as I don't think I'll be wearing them out . Even the foam is nice shame I won't be using it , a full set of 15 8-21mm for £38 time will tell .
