gaz1
- westyorkshire
i would use 2 of these one for either side lower
www.builderdepot.co.uk
then i could wedge the beam thats going to sit onto it before inserting it under the beam
then i would cross memeber the beam to under the old one so its pushing it upward but also supporting by crossways also pushing the joist hanger into the wall
that hanger gives wall support but also gives bolting access ino the wall giving further stability by bracing and also supporting
100mm x 225mm Speed Pro Masonry Joist Hanger Galvanised
Speed Pro Masonry Joist Hanger has remarkable strength without the need for a wide top flange. With no welds the Speed Pro Masonry Hanger is the only single piece masonry joist hanger with a straight top flange. It also has the key advantage that any standard Speed Pro Masonry hanger can be...
