How do you stop it moving around when you use it...??I chopped a foot off the bottom of my English wheel and started rebuilding it so I can bolt casters on but I ran out of gas on the last tac so that’s it for today.
Use 360 locking braked castors on all four legsHow do you stop it moving around when you use it...??
  Similar to these from RS but locable to stop them rotating as well as rolling ...you'll find them much cheaper in plated steel on line .That vacuum lifter is a good thing.We are starting again, next boat project, among other things. Got initial delivery of alli for the next pontoon / hire drive vessel. This time around the whole thing including the superstructure.
This is about half of the extrusions required, next is the plate.
This had to be dragged into the workshop with the forklift.
The new (first time usage of the approved lifting device), absolutely worked a treat.
It will lift and rotate the plate penumaticaly![]()
Piston broke?I’ve turned this Husqvarna 254
Into this and box of bits!
Carb needs a clean and rebuild. Sadly the piston is junk, cylinder is marked but I can’t feel them with my fingers. Replacing both. Hoped to keep as much of it original as I could.
Few horsepower there!We made it into the last field we want to plough ahead today, decided a photo/video shoot was in order.
View attachment 362226View attachment 362227
I shudder to think how much diesel you guys use!We made it into the last field we want to plough ahead today, decided a photo/video shoot was in order.
Piston broke?
Add your own joke
Which hardware is that Andy? I’ve got a few shelly smart relays I keep meaning to have a play around with…I’ve briefly tried one but only as far as powering it up and making sure it worked from the app.Just made the workshop extractor work from my phone.
It's a H&S thing as I no longer have stumble over carp on the workshop floor to get to the switch
