DAPPH
as dyslexik as I'm daft
I'd be ******** without my automatic time clocked water misting irrigation set up . I wasted lots of dosh trying to find things that worked & were reliable after eight or nine false starts I finally settled with Hoselock connectors to taps , Hoselock timers and Antelc variable spray micro misting heads & all the half & 1/4 inch neoprene tubing and all the connectors f& crimps from " Wetwise.co.uk " , I'd have saved three or four hundred quid or more if I' d found somebody with the knowledge in the first place & got their advice , but that's what makes experience an expensive commodity one way or another .Very possibly - I haven't been sure about how often they need to be watered, and was also trying to avoid watering them too much. I haven't been giving them food quite as often - just once a week (because I didn't read the packet properly) and I forgot for a few weeks. The plants are getting very warm in the afternoons as they sit in a greenhouse on the back of the house, and the sun comes around there from just after lunch and stays there until early evening. Unfortunately that's also the time I'm out, so quite often I'd get back around 5pm to find them quite badly wilted, so would give them some more water.
The greenhouse they're in is a lean-to on the back of the house. The glass roof panels were replaced by sheets of opaque glazing sheet a few years back, so there's some shade but unfortunately the roof opening isn't there any more. I want to put it back to glass when I can, but because the structure isn't square (it was installed on a concrete base that slopes away from the house slightly) I also want to strip all the glass out, square it up, and then re-glaze it. Because that's a big job, and requires all the junk to be emptied out, it won't be happening soon. Plants 24" apart? No chance. And if I transfer some to the other greenhouse, I'll probably forget to water them. But that also needs clearing out - it's been used as a junk store for ages and it's taking time to sort it. Lots of plastic things in there just drop to pieces when I touch them, and there's a wild sweet pea growing around the inside.
I'll try to remember all these things for next year, if I grow some more. Thanks for the notes.
