Came from BrundellsMay I ask what sliding door gear you are using?
I did mine by broaching in the lathe using a HSS bit and winding the saddle in and out.Haven't worked out how to do the keyways yet.
Yeah I'm thinking of that or same on the mill using the quill. I don't want to have to buy broaches. So making something in hss and slowly doing it will probs be my best option.I did mine by broaching in the lathe using a HSS bit and winding the saddle in and out.
The keyways are already in the shafts, it's the pulley keyways I'm struggling with!Or use the endmill and shape keyway to suit....
Have a very similar looking TEC motor I mounted recently to a Pollard drill.The keyways are already in the shafts, it's the pulley keyways I'm struggling with!
Thanks for checking. I think they sell mostly King gear. I need to make a door like the one you are doing, and hoping to find a cheaper supplier of the bits than brundel. CheersCame from Brundells
Can't find boxes or delivery note so no part No. Sorry
That's a good idea it will help to save time.I was also thinking of plunging a 7mm end mill in first to give me a half round keyway, then homemade hss 8mm broach to finish.
Use your mill to slot the keyway sideways - leave it round on the top as the key drives on the sides. Assuming you are securing with a socket set screw though the pulley onto the key, the key will remain in place in the shaft well enough.The keyways are already in the shafts, it's the pulley keyways I'm struggling with!
Pls can you explain, I don't see how I can do it sideways? Thanks.Use your mill to slot the keyway sideways - leave it round on the top as the key drives on the sides. Assuming you are securing with a socket set screw though the pulley onto the key, the key will remain in place in the shaft well enough.
I think I've worked out what you mean. Rather than plunge, lower the end mill to full depth of the inside of the pulley, then come in from the side. That's not a bad idea. I will probs need a longer end mill though.Pls can you explain, I don't see how I can do it sideways? Thanks.
