angellonewolf
- bristol england
This is the shim that's in there at the moment
And there's to much slack in there I'm ideally looking for 2 x 0.75 shims
Or 1x .5 and 1x1mm shim I think will do it
ive got penny washers but thats going to take off ..8 mm off to get the .5 shim thats a lot of work rather just buy one for a couple quidlooks like a big "penny washer" local nut and bolt supplier may have something to modify?
had one then sold it so thats outWhats it for?
You'll need a lathe![]()
I could laser cut a couple hot you. I have 1.3mm stainless or 1.5mm mild.
thankyou for the offers guys i will keep that as a last resortI may have some brass shim stock that could be cut to suit.
ive got washers but to get it right going to take a lot of work hence buying the right size idealyAnyone with some washers and a surface grinder ?
Didn't @25.4_mechanic buy loads of shim stock?
He may have something.
O.5mm shim stock. Cut a circle out of it.thankyou for the offers guys i will keep that as a last resort
also the one thats in there at the moment is 1mm the total i want to put in there is 1.5 mm hence 2x 0.75 as i need one on the top and then one on the bottem and remove the 1mm
or add a 0.5 shim to make the total 1.5 split
its for a hedge trimmer that keeps throwing the gear mech so im hoping adding extra pressure top and bottem will stop this
thats now not a bad idea a mate is getting shot of a washing mechine id bet the panelson there are as thin as possable even if there .7 mm i can make the 2 so it has .7 at the top and .7 at the bottemI've be making that from 1.0mm thick steel sheet if I had some, its simple metal work, draw the circle with some dividers, drill the centre hole, file the outside to the scribed line. (one or two steps have been missed but thats the general idea).
just cheaked ebay and thats now another optionO.5mm shim stock. Cut a circle out of it.
thanks for the offer but making one sounds easier now if i cant buy the right size and ebay has quite cheap shim stock if the washing mechine panels are not the right size1.5mm sounds like those nasty steel packing bands - tomorrow I can check what's closest to 1.5mm and send a collection around that measure fixed on paper with adhesive strips in a letter - that shouldn't have been affected by Brexit.
You can still drill holes, can you?!?!
Throw me a message,
btw.: I didn't buy, I saved them
Carsten
empty beer cans
