I admire your patience with those engines, I couldn't stop one from leaking, so...This SEL 1550 Majpr came my way the other day.
Normaly I do a air trest on the engines. But being a SEL my adaptors did not fit. So we went into steam.
It was funning slowly, with some odd noises.
Then the vapour escaped.
The leaks are from.
Level plug, Safety Valve.
Steam collection port.
Whistle.
This was the pain.
Collection head was split.
The thread insert had failed.
The pipe is held in place by the nut and a brass olive forms the seal.
Using flux, a small, but hot flame we heated the whole assembly up.
It was a nice surprize to see the solder run and seal.
It was not a perfect repair, it shifted a bit. A bit of gentle bending of the steam pipe was needed.
What this still can not show is the power it is now producing, the great sound and no leaks.
This Bowman is not going to be restored, I think it will loose it's charm.
Ok.I admire your patience with those engines, I couldn't stop one from leaking, so...
I can send it your way if you want a project.![]()
You just need to get that cat colour matched now and it'll look sweet.Clear coated the mazda last night, had to skimp on getting the finish properly done, not enough time for another round of filler and sanding and primer. Oh well it's a user, not a looker. Still I will color sand the panels and polish it up once the clear coat has hardened enough. The bottom of the front and rear wheel houses are new metal, as is the bottom of the sill the entire length.
Looking back at pictures of when I bought the tractor it was like that when I got it probably 8 years ago and I'd never noticed. Although a bit of oil was coming from the seal, the main leak was round the flange - the one bolt was still mighty tight.Explain ?No A check then
Explain?
