Brad93
- Essex, United Kingdom
Well I wouldn't use a stronger rod, I'd just use a nice 6013 which gives a soft ductile weld, with a very smooth surface finish and easy slag release.No doubt Brad but is there any advantage in using a harder/stronger rod to repair what is effectively only boiler plate?
Bob
I dunno just seems all wrong to clad with a 6010. It's a fast freezing deep penetrating rod.
A 4 or 5mm 6013 will lay metal down a lot faster. Blimey you could even use rutile iron powders.
On annual strip downs its better to have everything meticulously cleaned up and welded/repaired prior to the visit, its not like throwing an old banger in for an MOT and fixing what it fails on. To get a knock back on a steam boiler inspection is a real kick in the teeth. Second visit is a hydraulic test and thats when the decision is made as to whether the thing will be left running at the same pressure or down rated, thats another load of work.
