Think that's it. Used to lock in the work engagement depth iircThere's a grub screw tht holds the eccentric block into the body. Remove that and it comes apart.
I have a Hoffman RT, the hand wheel is similar in that it hangs lower than the baseAhh I see what you mean.
You reckon it's none standard? Or are they all like that to overhang a mill table?
Both clamps free. Anyway will have to wait a few days now. I found the vertex manuals so will have a look.Yes, it should. Unless you've one of the clamps tightened.
Very interesting thanks!Can't remember now. Been a few years. Pics here may be of use.
Cnc rotary table.
Some of you would have noticed I aquired a vertex hv6 rotary table yesterday. older generation still with bearings rather than running in the machined castings. needs a clean then I'm going to look at fitting a stepper to index with. Next to no backlash either. Came across this...www.mig-welding.co.uk
I never said you were wrongApologise?
I never said you were wrong![]()
Yes, this. And don't rush it - if you have to make a v block or an attachment to your press then do it.Need to get it between centers and get the dial on it to determine where the bend is, mark it and get it in a vice (soft jaws) and hit it with a copper hammer...might take a few goes but you should get it within what you need to allow it back in the table
I have 2 flypresses - but no balls - and a bent shaftYes if it really is only a few thou. As you say, all the effort up front in measuring and discovering exactly where the bend is is the key issue.
If it were me and I didn't have a flypress I'd prefer to go with a more controllable bend with the shaft in a vice and a long bit of pipe (or bending fork). At least then you can feel for the amount of bend and also direct the force much more accurately.
It's ok thanks - downloaded the manuals. Mine is the earlier version though with ball races etc - better quality than the newer ones - or would be if the shaft wasn't bent!Looks identical to my vertex, can’t help you too much with straightening shaft but I have Manual and parts diagram at home, though you can probably download from web….
I can send you pics/scans if you want (you may not need them as you already have it apart) but I’m in Turkey with work at mo and not home till Friday
Well you did an amazing job on a very bent feed screw on that milling machine! If that can be straightened anything can!Yes, this. And don't rush it - if you have to make a v block or an attachment to your press then do it.
Slowly slowly catchee monkey
