Funnily enough it would have been handy. Only Hitler had oneAt £6 you should have bought two.
Then the thread would have been called ....
Coat, door etc...
Where's the safety chain ?Got this today. Bargain about £6 on Ebay. Stunning finish on it. Why? Would make a lovely lethal walking stick handle
Anyway just attacked my forklift with a mag drill. Holes in both forks now.
My new trailer is a tad heavy to push !
View attachment 356174View attachment 356175 View attachment 356176
I don't use the forklift for anything commercial thankfully.Have a bit of box that slips over a fork with the ball on the end is how I've made them in the past. Couple of ears behind the the heel of the fork for a pin to go through.
Saves having to drill holes in forks...hopefully your insurance inspection man will put his clipboard over them when he does his checks.![]()
If it's personal use then it's personal choice. If you fitted longer forks or fork extnensions in the workplace you'd have to have the load centres re-calculated but again if it's personal use you can use the wheels lifting off the floor as a load gauge if you like.I don't use the forklift for anything commercial thankfully.
Why would 2 small holes make a difference? I bet they will to an inspector but logically what is the harm right at the tip? I kept the slugs - could easily glue them back in
I did think of making something to slip over but this was so quick and easy - no need for tools to screw on or off - the ball provides plenty of grip.
I do want to change the forks at some stage - they are a bit short which can be a pain.
It should have had longer forks according to the manual - must have been swapped out. Not much longer just a bit. Our neighbour has extension forks I can borrow any time I want but they are a tad too narrow so mine only go 1/2 half way and get stuckIf it's personal use then it's personal choice. If you fitted longer forks or fork extnensions in the workplace you'd have to have the load centres re-calculated but again if it's personal use you can use the wheels lifting off the floor as a load gauge if you like.
God I am slow tonight - very apt name for this topicAt work we have one bolted to a length of box section that slides over the fork and had a bolt that secures it by passing through a drilled hole behind the heel of the fork. Saves risking a fail at the periodic inspection.
EDIT: Hitch got there first.
Forum safety nazi.....Put a cable tie on it over that![]()
