I did move my phone into my pocket , as I normaly prop it in the window so as not to fill it with grinding dust , and admittedly it has made it better , but it only happens when in the afternoon when the sun is beaming through the window . It’s not all the time , just when I am / the visor is at a particular angle .Any phone screens in view near window?
I use mine outside without problems but I was suprised my phone screen and tv triggers it everytime, unsure why, older phone is no problem.
Mine works perfectly outside in the sun, I do everything outside. May be a bad /over sensitive one and worth getting a replacement?I did move my phone into my pocket , as I normaly prop it in the window so as not to fill it with grinding dust , and admittedly it has made it better , but it only happens when in the afternoon when the sun is beaming through the window . It’s not all the time , just when I am / the visor is at a particular angle .
I gave up trying to use it outside as it just flashed the daylight out of me .
I am not to worried as for my £40 I am still happy and accept it is not a £400 mask .
@Onoff Side windows are a proper welding shade with IR and UV filters, cant remember what number, 8 or 9? a bit light but its not going to hurt you. Ive done some beads looking at it through the side.
Ta. Is that a guess ref the side window shade? Couldn't find anything online. Maybe it's in the manual? Is there a manual, didn't notice?
I note it's True Colour. Pretty amazing given the price.
Used the Ginour mask in anger today. Just to stick an angle X brace together with the little Aldi inverter stick. I'm narrowing a set of shelves I made years back by 100mm so as I can get a cupboard in next to them. Ground and painted to hide the embarrassment but it's not going anywhere!
Only pita is switching between grind & weld. The switch is up inside the mask and with gloved hands you knock the other controls. Then I forgot to switch back to weld after tacking it and got a good flash!
You got dazzled not a flash![]()
Probably because the sun was so bright.OK so why couldn't I adjust the mask to stop it?
Don't know but there's enough screen to stop the UV damage that causes flash. If it's sunlight causing the triggering you need to get it under cover.
Im still getting the flashing , tried changing the settings , less shade , more shade , less sensitive , more sensitive . No difference , just harder to see or brighter when welding .That's the thing, I was under the shade of the awning as in in shadow.
Mine arrived this morning.
The headband seems a bit lightweight, but I'll not be putting this to commerical use and I expect it will last long enough.
Fun and games putting the headband back in after I'd removed it to gain proper access to the dark module to check the batteries.
I'll see how it shapes up, but initial impressions are good.
I just bought one of these because my GYS Spaceview has gone wrong again. Should be here today so I'll give it a test run.
I like the spaceview but it's been unreliable and the build quality of the sensor module isn't great.
