rcx132
Philip
- London, UK
I've been fitting an irrigation system to water plants and sprinkle the lawn. I have over ground poly pipes running down the side of front and back gardens which then breaks out into the hoses that feed the lawns and flower beds. I've had to use multiple pipes to "zone" the system for it to work well.
I'm thinking of using motorised valves from plumbing shop to automate the system. I'd splice 15mm copper off the mains water, check valve, split to three motorised valves, and then to the poly pipes feeding each zone.
I could have the motorised valves in the house. They'd be in the under-stairs WC and be a bit unsightly. Or I could take the mains water through the wall into an outside cabinet and have the valves there, but they'd be outside and subject to frost and humidity.
The alternative option is to fit another outside tap and use a battery powered Hozelock distributor, like most people do, but these plastic low cost devices aren't reliable.
What do you think ?
What do you think ?
