Onoff
- Sevenoaks, UK
Tomorrow I will try doing the plaster, as Im going out soon.
It's raining today
Life's too short to stuff an olive , so is making your gasket ring , you're over thinking a simple solution .Rather than using the rubber sheet (?), is there any mileage in 3D printing a TPU ring gasket? Thinking less rubber to de-gas and make "smoke", if indeed that's what it is. Sized for that particular CHS of course.
KISS ???
RememberKISS ???
Simply stick the tube to a flat plate using " Bosticks Sticks like Shi* " cartridge gun glue , gluing up the tubes rim & run a thicker bead round the outer edge of the tube , clamp it in place with F clamps till it cures in 24 hr .
For the top get whatever you are going to use for the lid put the evacuation holes & any union threading's in it
For the lid ... Stick a large square of sticky backed plasticto cover the top plate wrinkle free , run a thick ring of " Sticks like " round the rim of the tube , invert the tube to sit on the flat top of whatever lid you want on it , again run a thicker bead round the outside & clamp up for 24 hrs .
Assemble & test ?
Vacuum alone will pull the ends down onto the rims , peel the sticky plastic off or leave on.
Once the vacuum is broken the pieces will part easily enough .
Yes that would be great if you can.Rather than using the rubber sheet (?), is there any mileage in 3D printing a TPU ring gasket? Thinking less rubber to de-gas and make "smoke", if indeed that's what it is. Sized for that particular CHS of course.
This should be here soon, should be adequate? Whats the advantage of vented, oil filled?Definitely get a new gauge - a vented oil filled is what you want (I assume that's the only reason you've got your hand pump still plumbed in) and simplify your plumbing. My set-up has the gauge and ball valves (very handy) as one assembly then just a single hose to the pump.
Shock dampening from the pressure pulses leading to better accuracy and longevity... especially on cyclic applications.Whats the advantage of vented, oil filled?
A nice soft silicone for the gasket will be ideal...that way the seal will improve under higher vacuum.
Not sure FDM printing a seal is a good idea - it's potentially full of holes!
I guess the print path could be important? If it loops the circumference may be better than radially outwards. One print groove crossing the seal instead of many. I know nothing about printing, that may not work.
tape I found amongst the **** a previous owner had
left in a car.
