Haha, it certainly looks like it's built like a tank, old school and very solid! Ah, so if it's 24v, connecting it up to a single 12v battery might not have shown anything? Will see if I can find two that hold charge to try with 24v.Those old sip ideals were built like tanks,i had one,huge machine(and have to admit,never missed a beat),i think if i remember,the motor are 24v DC i could be wrong,so you'll need to check this out.
Heres the good bit,i may have a replacement,let me rescue it from the depths of junk i have and see if i can match it up with your photo
Thanks for the welcome Mike, good to be here, looks like a great resource.As it's a DC motor, chances are it has brushes which could be sticking. if you can locate where they are then a blast with some switch cleaner and a tap with a screw driver handle may free them up. Note even though the OUTPUT of the gearbox may run very slow, the motor may run at several hundred rpm's
And welcome BTW![]()
Did you get it sorted?Thanks for the welcome Mike, good to be here, looks like a great resource.
Good point with the brushes. I need to take disconnect everything anyway, so will see how easy it is to get to them. It seemed dead as a dodo, though, but maybe firing in the full 24v will give it a boost too.
