God mode restorations
- uk colchester
Thanks Brad. Slowly getting there.Gardens looking a lot more like a garden now mate! Nice job
Oh a W. German hpc good machines.My screw compressor has been disconnected since the start of Covid when I moved it to build the bar/cinema. Time to get it going again as I have some blasting to do and hopefully some spraying, also I need to cut up some bits of steel with the plasma.
I hate machinery that is a pain to move, and this is one of them. The gap between the cylinder legs is too small for the short pallet truck and there's no lifting eyes. It's been on a piece of ply resting on some blocks since I moved it upstairs.
So I cut four lengths of 50mm box into 550mm lengths and welded two lots under each leg, offset about 20mm so the pallet truck can squeeze in.
Lifted up with straps, welded the extended feet on, coat of smoothrite and back onto the pallet without the ply and blocks.
Back to it's new home.
It's a bit of fannying about but I'm going to be painting the floor soon, plus to service it you need to access the panel at the back. It cost zero as it was heading for the skip with 20 hours on the clock. It's now got 34
It will never be pretty given its poo brown and horse phlegm colours, I may have to give it a face lift with more sensible colours but for now the feet, a new 1/2" water separator and a few new hoses should make it run nicely.
I've been told they don't like not being worked, got to get them hot. Even if you only want to inflate a tyre, keep them running with the drain out for a while. Rather than do that, which sounds expensive leckie wise, I have a single phase 3HP compressor downstairs, eventually I'll plumb them into the same system as I have a dryer and big regulator.@brewdexta most important part is keep the cooler clear these also have an oil stop valve.
We had one that would momentarily shut off causing the airend temp to shoot up had 3 guys to it no fault found.
Just by pure luck it did whilst I was onsite, IR cam picked it up.
Also these have a gauze inside on the scavenge line keep it clean or it will pass oil.
Other than that these are pretty reliable
I thought the drivers knees where the designated crumple zoneStarting to make my old camper a bit safer for the occupants,starting with this bar at the front,I’m planning on tying it into the chassis rails by slotting plates thru the floor.used some rare stock 30/30/4 box.As you’ll see the end flanges had to be shaped in both directions.
Next will be 25 box thru the doors,starting with the cab
Neater than my first (and only).View attachment 350967View attachment 350965 a cube for the sake of improving starts and finishing,
I have similar trouble, in particular when trying to line up to cut along a scribed line on a sheet which is long than the lower blade - I'm trying to line up by eye, but usually have to try to correct it part-way along the cut. I bought a little laser pointer with the intention of mounting it on the top blade so I could point it at the edge of the lower blade, so when the sheet is in place I know where I'm putting the back end of the line. Only had that sitting on the shelf since about 2019, so there's time yet.Chopper needs some kind of guide to keep the sheet square, but its a lot better than I could do with grinder.
I like your choice of components, but I've got serious reservations about using the plywood for motor/compressor mounting. There's a large amount of vibration and torque going through it. At best the mounting holes with stretch/elongate; at worst, you'll have a complete failure. You'll struggle to put enough tension on the fasteners in the plywood - it compresses fairly easily. How will you adjust the belt tension? What stops the motor/pump moving over time?I decided to use a piece of plywood to mount everything on, simpler than working in metal. I mounted the plywood sheet on springs to reduce vibrations, but maybe some thick rubber might work better.
ok, no worries, I've never done it and never would either, but as long as it works for you.Sounds like complete nonsense to me, have had motors mounted on plywood for nearly a decade without problems... Such a thing as washers.
I'd have to agree with you in this instance, for use driving a compressor - I could see it coming loose quite quickly once running and vibrating nicely, simply from compressing (no pun intended) the wood, even with big washers.ok, no worries, I've never done it and never would either, but as long as it works for you.
First attempt with stainless sticks.. my test beads came out nice and shiny.
