Bravheart
"Tomorrow will be a good day"captain Tom1920-2021
- Scotland
ha ha I saw that as well and thought that's not for me then, must be in the wrong shop!I just saw PRO on the can!
Metric??Just back from a very pleasant holiday in France. I'm not one for souvenirs (unless you count the lovely Breton Cider), but I did take advantage of being in a civilised country and popped into a DIY store to pick up a few measuring thingies, all completely unadulterated by Boris' bulls**t units:
Even in France, it's surprisingly hard to find rule(r)s (like the Stanley one in the picture) with whole millimetres on both edges of one side and half-millimetres on both edges of the other side. The Facom Dela ones are the only available-in-the-UK ones I've found like that. The Axminster ones are nearly as good (whole millimetres on one edge of one side and half-millimetres on t'other but when you flip it over, the edges are swapped), but it's much more convenient to decide whether you want millimetres or half millimetres and then use whichever edge is easiest, rather than flipping the ruler over repeatedly. Me? Fussy about rulers? Never!
Brother came over from Sweden last week. Asked him to bring the same. And a couple of folding rules. Zollstock in Germany, no idea what they’re called here but hard to find.Just back from a very pleasant holiday in France. I'm not one for souvenirs (unless you count the lovely Breton Cider), but I did take advantage of being in a civilised country and popped into a DIY store to pick up a few measuring thingies, all completely unadulterated by Boris' bulls**t units:
You have a "rule".Just back from a very pleasant holiday in France. I'm not one for souvenirs (unless you count the lovely Breton Cider), but I did take advantage of being in a civilised country and popped into a DIY store to pick up a few measuring thingies, all completely unadulterated by Boris' bulls**t units:
Defeatist .!
Psst!Would you be so kind as to put me on number 3, pls?
Carsten
I have similar ..In my ancient 1943 lather with taper roller bearings I've found the best results with little strain on the head stock bearing is to put the RMP very slow and feed in 1 thou or less every 20 to 30 seconds till you get the depth definition you require . Make a note of the feed dial reading so you get the rest the same depth if you are extending the knurling along the bar or rod@25.4_mechanic
Push in type:
It's held in the toolpost and pushed into the work with the cross slide. It does impose a lot of strain on the headstock bearings.
What Is a Boris bullsh1t unit?!
You have a "rule".
These are "rulers":
You'd be slapped with one or the other if you got it wrong in our place![]()
I was looking at that soldering tool trying to work out what it was for and whether I was missing out!Two croc clips with solid conductor feed wires attached & cut off to 20 mm legs
Zollstock
Yeah, yeah....I have a twelve-incher, but I don't use it as a rule.
That will clean up very nicely !Pulled from the scrap skip at work, one of the lads swapped it off his workbench for a nice new blue vice.
And yes the nice new blue vice is a no name 30 quid article.
Thank the lord there are people like that in this world!
That looks very clean. I´m looking for a shaper.Hi, hope everyone’s o.k.
Oh dear, this seems to have made its way into a rented van.
But of course like me you've never ever forgot to put the fully shrouded plug cover on the mains cable before putting the wires in the plug's pins & fuse connection .I was looking at that soldering tool trying to work out what it was for and whether I was missing out!
Now i get it....but I just use heat shrink solder joiners when doing car stuff....basically can be done with one hands and a heat gun as they solder and shrink all in one....which is perfect for me as I always used to forget to feed on the heat shrink until I'd finished the joint!
