Maker
Most folk just call me; Orange Joe
- Keeler crater
That's the one. You might find you need to replace that thumbscrew for a nut and get a spanner on it, it takes a lot of force to cold-form knurls.
Anti-Rust means it will not rust easily
Rust resistant means it will not rust easily
Anti-Rust resistant means it will resist the Anti-Rust so will easily rust .
Same as someone pleading their innocence by say I never did nothing, that actually means they did do something
I made a knurled circle for mine till I found out I could not wrench down on it properly so milled some flats for a spanner works a lot betterThat's the one. You might find you need to replace that thumbscrew for a nut and get a spanner on it, it takes a lot of force to cold-form knurls.
I spotted that.I made a knurled circle for mine till I found out I could not wrench down on it properly so milled some flats for a spanner works a lot better
Here's some photos in use works well alothough my tolerances could have been better,a little bit more movement than I need
I suppose , The thing to consider with the clamp type is they are diameter restricted so if it doesn't fit in between them you would be stuck , With the push in type you could push them into any large diameter and knurl away.Would you agree?
Thanks
Carsten
Tailstock can be good for start parting but theres a risk of jamming the blade so needs a bit of care. If your parting off tube from solid bar and bore that goes past the parting line its perfect to put a tailstock centre in.Can you put a tailstock on that? , Only gripping a small part of the stock, quite large dia and stick out while parting off that can apply some decent loads
Im no full-time turner but done some training and occasionally at work and home and that setup doesn't look ideal for rigidity or work holding.
Another way is back the cross slide out a little from centre, wind the knurl by hand, move the cross slide in to centre with the part spinning slow. Works for me as I can never find the adjustable.That's the one. You might find you need to replace that thumbscrew for a nut and get a spanner on it, it takes a lot of force to cold-form knurls.
push in type
About the only thing impressive, there's some funky headstock + 3 jaw misalignment which I cannot figure out resulting in it producing 0.05mm difference over 2" on some parts ¯\_(ツ)_/¯Push knurlers are rubbish. My RDG clamp type was not big enough for something so tried the spare push, wouldnt even do aluminium. When I get round to it Im going to remake my clamp type bigger, and with the pivot further back, to use less cross travel.
@Bki26 that is damned impressive for that little baby lathe
Indeed, I have also noticed that there is a completely different category of knurling tools: Suddenly it costs 50 times as much and I don't understand why ....
Thanks,![]()
Hey, less of your cheek young man. I never use it to grow a part that I have made a 'Doo Doo ' of ..... As @Hood has pointed out in the past though, you cannot use cut knurling to "grow" a part to get you out of the Doo Doo if you have made it too small!
In truth the only time I use it is for cutlass bushes on boats where the tube is oversize (for various reasons) and the only other option would be great expense and weeks of waiting for a custom bush to be made.Easier to blame the anodising process when the shaft is too small or the hole is too big![]()
They work great on bigger and sturdier lathes.@25.4_mechanic
Push in type:
It's held in the toolpost and pushed into the work with the cross slide. It does impose a lot of strain on the headstock bearings.
Dough!
Usually put butter and jam on mine.
Picked up a spool of gasless wire and saw this stuff. There was a choice of water based or oil based. What are they for and what's the difference?
Anti spatter spray it Stops welding spatter from sticking to your mole grips, clamps ect.Picked up a spool of gasless wire and saw this stuff. There was a choice of water based or oil based. What are they for and what's the difference?
