I might take that off your hands if you really don't want it, I've been after a cheapish one for a while... No worries if not thougha D1 swiss tech made in china guess what it doesn't come with a case and needs an app for full function
Maybe destined for the glove box ,thought it was cheap !
Today I acquired some professional graffiti.
I'm having a knee op today and the surgeon drew this on my leg!
I'm sure he's having a laugh at my expense![]()
Then he will probably have had a thing or two to say today ...Nice bloke and we always have a chat about the state of country.
and I wouldn't thing Magnet would be selling knock offs. I now some of the Bosch ones are silly money.Did you buy that new Bob? I need one to put above my milling machine to lift the attachments on and off.
Don't want to rub it in but these aswell
Says the person who is probably for half the posts on this thread in the past few weeksNice of you not to rub it in, a real pal.![]()
I'm sure he could hit higher notes, though.I'm sure he's not, Brother in laws Brother had the wrong ball removed then had to have the other one removed.
Compensation was quite high.
So its this, the part I showed the picture of is sandwiched between those 2 big washers on the left of the shaft, as the hay is stuffed into the chamber it turns that big angry spiky wheel that turns the shaft and the roller im replacing, the arm above it is tight against the roller so as it turns it lifts the arm up, when it reaches a set point your bale is done, the problem is the friction between the roller and arm or lack of friction so hope fully this should sort us! every year I keep looking at it thinking of betters ways to do it but you need a field of hay to test the ideas!
could be off a commercial dish washer poss the atuomatic detergent feedA peristaltic pump.
Needs a 24V AC supply, so I haven't tested it yet. It looks like there's a hall effect sensor for feedback too which I might try to read. Not sure what I want it for, it's about a 1mm tubing so very little flow rate at presumably quite a high pressure. Its just more treasure for the pile now.![]()
And fewer people around that have any experience of them.It could be worse, that's a simple mechanism, if the knotters go wrong you're in a real level of pain.
