Screwdriver
This might be handy. I found the home made cam grinder quite interesting.
Interesting. It didn't show how he milled the lower 'hidden' can profile, or did I miss it?This might be handy. I found the home made cam grinder quite interesting.
“We’re all doomed”....I can’t see this ending well …
All that hard work spoiled by an out of flat stone, shame. And yes, I was expecting a camming action from somewhere, and yes also, he didn’t show the machininge of the hidden lobe - probably used a t slot cutter?Interesting. It didn't show how he milled the lower 'hidden' can profile, or did I miss it?
And was he just freehand grinding the cam profiles, to clean them up, or did he have some profile device to pull the cam in and out while it rotated?
Certainly to 1.5 thouI really can't see the point of free-handing the grind. It is very unlikely to perform as it should.
My OCD wouldn't allow me to do that, even with the relatively small error. Having gone to the trouble of putting together a grinder, why didn't he finish the job and control it with a master pattern?
Link?check out john renwicks workshop on you tube he shows you how to on a home made camgrinder
ps ive been welding and grinding cams for my vintage 1 cyl engines for years with good results it takes ages with a degree wheel base circle is easy its blending the profile thats hard
try john renwick vincent
