I've always waited till everything has returned to normal colour before i attack with a spanner,normally use a ring spanner or socket rather than an open ender...
What size drill are you trying to pilot it with Steveo? If it's around an 8mm(?) bolt, try under 3mm. File/grind it flat as you can and centre pop, give the drill a lick on the grinder - if it doesn't cut, don't persevere, back to the grinder and try again - if you dull the edge on the drill, back to square one. Should cut with very moderate pressure, otherwise broken drill to add to your woescant drill right through ..it leads to inside the manifold
just been trying to weld a nut on it , just keeps snapping the weld when i turn the spanner
my drills barely touch it either
Once you get through the surface hardening should be straightforward, you'll feel the break-through at the end of the bolt. Wish you were nearer, would remove the (offending item) for you
), don't feel bad if you have 3-20 goes at it
When it cuts, you'll know
