roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
Looking goodGetting there now. Retorqued and ran through the valve clearances, mis-fire sorted and ran well with no leaks. A quick look at carb balance and it's all good straight off assembly surprisingly. I'll check again once it's had a bit of a run to warm it up under load. Breather top is here, so all I'm waiting on now is a set of case/cover bolts to arrive in the post.
Then I'll be able to get all the bodywork put back on (carefully!) and it can have a run up the road to see if anything creeps out of the woodwork after a long layup.
