mike os
just a little insane.....
- North Wales
It’s norgren… it’s what they doThat looks very much more engineered than the ones I have.
I like that
I like that
I bet that's costs more than my compressor cost me though.That looks very much more engineered than the ones I have.
I like that
I’d be surprised …I bet that's costs more than my compressor cost me though.
My thinking is simple. The 9cfm of Free air delivery isnt enough for what your trying to achieve. Use less air, or buy a bigger compressor.Its a 90 ltr , 3 HP, 9 FAD, compressor. I find that at 125 PSI , the differential in pressure is to wide and lose pressure quickly. I found I could get a more constant 100- 90 psi having a higher cut in point.
I like to pump it up to 145psi, and let it cool for a bit, it seems to leave most of the water in the tank that way. I do this when I'm using a spray gun or home made grit blaster.
I know it uses more energy and , places strain on pump and motor etc, but I only use it occasionally.
I hear differing points of view on this subject, What is you thinking.
I stripped a few of these valves down today, to have a look. I can tighten the cap that retains the springs, I found a pair of circlip pliers that fit well. Now I'm wondering whether , they are set by different rated springs, or wether it's just a matter of the spring being loaded by screwing the cap in.I know? Not just 1 but two. Here's a photo of one of them.
I can't see all three of my pressure gages being wrong?
But as you say I don't like taking to many risks with compressed air cylinders.
I'll have ago at tweaking it in very small incruments and see how it goes.
Thanks for your advice
I know I sound arrogant, but I think I can run this one at 145 PSI when I need too for blasting motorcycle brake calipers and occasionally using my Lidle impact gun.
Those are the ones I need for peace of mind. Thanks . I'm thinking I only paid £90.00 for my compressor though ! I've already had to fit new mains and a con rod to the pump and spending any more on it at this point is not economical . I may just have to concede, and get my bank card out.A couple on eBay:
Pressure Relief Valves 1/4" & 3/8" BSPP | eBay
Find many great new & used options and get the best deals for Pressure Relief Valves 1/4" & 3/8" BSPP at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
1/4 Bsp Safety Blow Off Valve,11 Bar,160 PSI Pressure Relief Valve & Certificate | eBay UK
BSP THREAD DATA. 1/4 Bspp ( Parallel ) Safety Blow Off Valve. Pressure Relief Valve. Thread Size. For Compressed Air only.www.ebay.co.uk
Just been thinking about this! Correct me if I'm wrong but if the receiver is Pressure tested to 15 Bar? Then it shouldn't split or fragment till at least 35 Bar?10 bar is max working pressure for a small compressor….on a good day with the wind behind you when everything is new and valves unworn.
good luck!
plus who would run their Hobby compressor over what the safe working pressure on the tank indicates? Any way in the event of failure, it would likely be a ' Pin Hole' in the receiver due to internal corrosion.My thinking is simple. The 9cfm of Free air delivery isnt enough for what your trying to achieve. Use less air, or buy a bigger compressor.
Relying on condensate dropout due time in the tank will end badly. You need alternate means to remove moisture.
When new, with no internal corrosion, no fatigue from a million pressurisation cycles and no dents etc, it will have been safe at 15 bar if that's what the plate says. 30 years later having been sat half full of water and gunk it's anyone's guess. It may only have a fraction of the material thickness left at the bottom.Just been thinking about this! Correct me if I'm wrong but if the receiver is Pressure tested to 15 Bar? Then it shouldn't split or fragment till at least 35 Bar?
If your lucky, if not its goodnight Vienna!Any way in the event of failure, it would likely be a ' Pin Hole' in the receiver due to internal corrosion.
I tested hundreds of PRVs of various types in a previous job and whilst they were often a bit off, especially when old, they were generally fairly accurate. Where are you measuring your pressure from, and where is your PRV situated? On the tank or on a feed/ take off line?So' to recap. I have this week purchased two 11 bar PRVs , they cost twice the price of other generic PRVs but not the most expensive.
They both blow off before 9 .Bar
Is there something I'm over looking?.
I'm no expert , not an engineer etc' I trust the supplier, just can't understand what's going on? Can pressure gages go that wrong? It's a big differential between 8.5 - to 11 Bar?
I have seen electric motors that were overloaded fail in under six hours due to the increased operating temperature/current. Without checking the motor current when the compressor is close to max pressure. I always check current load on motors rather than rely on pressure gauges for operating pressuresI know it uses more energy and , places strain on pump and motor etc, but I only use it occasionally.
Some years ago I bought a good quality pressure gauge from the Budenburg company and kept that aside from general use so that it became my test standard for anything else I bought with a pressure rating. It did costs few quid, but I like having it to hand. Periodically, I used to send it off for calibration, but haven't kept that up.Without wishing to be all H&S I'd suggest that before you start adjusting them, it's worth getting a certificated pressure relief valve (there's a big difference between "yes we've tested it" and an actual certificate), or test your gauge against a known good (calibrated) one to ensure it is correct.
The last thing you want is an air receiver failing.
Well…..depending how scientific you want to get. If the max allowable working pressure is 10 bar, this is set by the PRV. At the manufacture stage a hydro test would be done to 150% of MAWP.Just been thinking about this! Correct me if I'm wrong but if the receiver is Pressure tested to 15 Bar? Then it shouldn't split or fragment till at least 35 Bar?
