I'm sure it depends a lot on the brand as well. Unless you need new batteries I wouldn't buy 5ah if I had good 4ah already.You’d expect them to last 25% longer but it’s a case of whether you’d notice or not. If you got 20 minutes of constant running out of say a drill, would you notice the extra 5 mins of theoretical run time?
One thing I noticed with a bigger capacity was its cold weather performance, the extra capacity meant it lasted longer especially when discharged but that’s a bit of a niche example and probably not enough justification for the disadvantages associated with a larger battery…
My flexvolt batteries are big heavy lumps. 54 volt though. /or 18 if I put them in an 18v tool.I use Milwaukee 18v 5Ah and 12v 2Ah.
Run times and charging times always supprise me! 18v 5Ah battery charges really quick.
It is just the weight of big batteries I don't like.
obviously 1 percent more powerWhat type of runtime difference is likely to be noted between those two; Minimal or notable?
all depends on the quality of the cells that are being used, a battery with a lower AH (and less internal resistance) may give longer duration that a high AH battery with a higher internal resistance under load.
I asked some Chinese factories for a price to get a load of fake DeWalt ones. Hoping to beat eBay prices which isn't hard. They asked me what ah I wanted, then what ah I wanted printed on the outsideThis is all assuming stated AH is the same as actual AH.![]()
Cheers chaps. It's the Makita 18V LXT batteries I'm wondering about. I have six 4AH, but that mower goes through them at a rate of knots, especially whilst the grass is growing at the rate it is. Was simply wondering if plumping for some 5AH may make me spend notably less time rotating & charging them whilst mowing.
