As per the RH one, surely?
Only one O ring needed, on the inside of the rim.
Mine are 11 to 12mm.standard valve cores fitted to every hgv wheel ive worked on are as so:
Pardon our interruption...
www.ebay.co.uk
Not sure about using them on a lorry. Would normally use a pul through type.
We have approx 1600 hgv wheels on site not seen any rubber valves yet, but as its tructyre you never knowThe one on the right is the correct way around. Not sure about using them on a lorry. Would normally use a pul through type.
Mate of mine has some good contacts. Place he gets all his lorry tyres from has found me 3 part worns for £30 each
I've got a very good Bridgestone that's out of date for the steer axle you can have for nothing if you want it.Mate of mine has some good contacts. Place he gets all his lorry tyres from has found me 3 part worns for £30 each
Good enough for my trailer!
