mtt.tr
- Essex/Suffolk border
What's the alternative?Yes, but not needed in my experience, unless you want to save 5 minutes - less probably.
By ear?
Sigh ^^What's the alternative?
By ear?
Sigh ^^i
Try a vacuum gauge and then tell me a rubber pipe stuck down your lug hole is better..carbs not balanced will not show up on a rolling road as its normally full throttle and main jets feeding fuel and not pilot jets.I know attendees to this site like to over complicate, but flippin' 'eck.
If you've never done it with a bit of tube, try it. If you can hear the hiss, its surprising accurate way to do it - my mate turned up with a set of those synchrometer balancer and couldn't tell any difference.
Been playing with twin carb set ups, Webers, Solex, Dellorto, and SU since I was 18, 34 yrs ago (crikey ), as well as a couple of Jenvey throttle body set ups - and assuming the jetting is correct/needles etc, I've managed so far without anything other than the hose idea - cars have been checked and tuned on rolling roads, but I can't recall anyone complaining my balancing was off.
Not when mapping for trialling use . . . lots n lots of partially open, in slightly increasing increments . . .Try a vacuum gauge and then tell me a rubber pipe stuck down your lug hole is better..carbs not balanced will not show up on a rolling road as its normally full throttle and main jets feeding fuel and not pilot jets.
Yeah, I've got the same issue - maybe spent too long as a youth with an angle grinder inside the wheel arches of old cars . . .Even with non stop tinnitus.
I'll balance my 4pot Kawasaki then I'll put the gauges on. I know my ninja is terrible with the slightest imbalance
