Id guessed Hardly AblesonLooks to be a Triumph Explorer???
Yep and a sintered oneIs it an SLS printer that can do nylon or polycarb blends?
Because there's plenty of end-use parts already on production automobiles made like that for small volume or options.
Wouldnt a carbon manufacturer be the person to ask ,, hardly a welding job.Ok so I posted some pics for everyone to see, if it was made of carbon fibre then what time scale would each item (both sections F&R) take to make from start to finish including trimming off at the end and fitting (or moulding in) any location lugs? (I don’t want an eight hour day on each item for example as it just isn’t worth my time.)
And why wouldn't you use that for a production part?
Crushed PLA can be squeezed through a hot nozzle using a drill bit too, never thought to use it for injection moulding though, I might try that.For stuff that's not going to see over 40c then polymorph type granules can be extruded easily through a nozzle made from a soldering iron and driven through by a screw powered off a cordless drill.
Once set that stuff is about the same as nylon in stiffness and toughness.
I can print PC-ABS on the FDM Stratasys printersIs it an SLS printer that can do nylon or polycarb blends?
